Ir para o conteúdo principal
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
O que você precisa
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, imagem 1 %32 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, imagem 2 %32 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, imagem 3 %32
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, imagem 1 %32 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, imagem 2 %32 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, imagem 3 %32
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: passo 3, imagem 1 %32
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: passo 4, imagem 1 %32
    • Using a soldering iron, melt the solder in order to free the auxiliary jack.
    • Como soldar e dessoldar contatos Use soldering gun with care as it becomes extremely hot and can cause burns
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 5, imagem 1 %32
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 6, imagem 1 %32
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
Conclusão
Bradley McHugh
Membro desde: 03/10/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G5, Baechle Spring 2017 Membro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 644
