Ir para o conteúdo principal
Craig Electronics CMP773 Volume/Power Control Button Replacement
O que você precisa
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: passo 1, imagem 1 %32
    • Remove the two 3.2 mm PH000 screws near the charging port.
    Pergunte ao FixBot
    Comentar
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 2, imagem 1 %32
    • Pry the back cover from the device along bottom edge.
    Pergunte ao FixBot
    Comentar
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 3, imagem 1 %32
    • Continue prying along each edge of the device until back cover is free.
    Pergunte ao FixBot
    Comentar
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 4, imagem 1 %32
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
    Pergunte ao FixBot
    Comentar
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 5, imagem 1 %32 Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 5, imagem 2 %32
    • Remove the old button and replace it with the new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
Membro desde: 03/26/18
171 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G5, Harley Spring 2018 Membro de IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 463
