Ir para o conteúdo principal
Craig CMP801 Volume Controls Replacement
O que você precisa
    1. Craig CMP801 Volume Controls Replacement, Back Cover: passo 1, imagem 1 %32 Craig CMP801 Volume Controls Replacement, Back Cover: passo 1, imagem 2 %32
      • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 Volume Controls Replacement: passo 2, imagem 1 %32 Craig CMP801 Volume Controls Replacement: passo 2, imagem 2 %32
      • Use a metal spudger to separate the back cover from the front touch screen.
      • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
      Pergunte ao FixBot
      Comentar
    3. Craig CMP801 Volume Controls Replacement: passo 3, imagem 1 %32 Craig CMP801 Volume Controls Replacement: passo 3, imagem 2 %32
      • Continue to separate all of the clips around the device until the back cover comes off completely.
      Pergunte ao FixBot
      Comentar
    1. Craig CMP801 Volume Controls Replacement, Volume Controls: passo 4, imagem 1 %32 Craig CMP801 Volume Controls Replacement, Volume Controls: passo 4, imagem 2 %32
      • After taking out the back cover, locate the black flap.
      • Open the black flap with the plastic opening tools.
      • Be careful not to break the flap when you open it.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 Volume Controls Replacement: passo 5, imagem 1 %32 Craig CMP801 Volume Controls Replacement: passo 5, imagem 2 %32
      Ferramenta utilizada neste passo:
      $3.99
      • Once the tab is released, use the angled tweezers to take out the tab.
      • Be careful not to scratch the tab.
      Pergunte ao FixBot
      Comentar
    3. Craig CMP801 Volume Controls Replacement: passo 6, imagem 1 %32 Craig CMP801 Volume Controls Replacement: passo 6, imagem 2 %32
      • Use the angled tweezers to pull the volume controls out and replace it with a new one.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 30
Ao todo: 608
