Ir para o conteúdo principal
Craig CMP801 LCD Screen Replacement
O que você precisa
    1. Craig CMP801 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32 Craig CMP801 LCD Screen Replacement, Back Cover: passo 1, imagem 2 %32
      • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 LCD Screen Replacement: passo 2, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 2, imagem 2 %32
      • Use a metal spudger to separate the back cover from the front touch screen.
      • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
      Pergunte ao FixBot
      Comentar
    3. Craig CMP801 LCD Screen Replacement: passo 3, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 3, imagem 2 %32
      • Continue to separate all of the clips around the device until the back cover comes off completely.
      Pergunte ao FixBot
      Comentar
    1. Craig CMP801 LCD Screen Replacement, Volume Controls: passo 4, imagem 1 %32 Craig CMP801 LCD Screen Replacement, Volume Controls: passo 4, imagem 2 %32
      • After taking out the back cover, locate the black flap.
      • Open the black flap with the plastic opening tools.
      • Be careful not to break the flap when you open it.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 LCD Screen Replacement: passo 5, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 5, imagem 2 %32
      Ferramenta utilizada neste passo:
      $3.99
      • Once the tab is released, use the angled tweezers to take out the tab.
      • Be careful not to scratch the tab.
      Pergunte ao FixBot
      Comentar
    3. Craig CMP801 LCD Screen Replacement: passo 6, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 6, imagem 2 %32
      • Use the angled tweezers to pull the volume controls out and replace it with a new one.
      Pergunte ao FixBot
      Comentar
    1. Craig CMP801 LCD Screen Replacement, Battery: passo 7, imagem 1 %32 Craig CMP801 LCD Screen Replacement, Battery: passo 7, imagem 2 %32 Craig CMP801 LCD Screen Replacement, Battery: passo 7, imagem 3 %32
      • Locate the white plug next to the battery.
      • Use your fingers to pull off white plug that connected to the battery.
      • Be careful not to pull or break the wires on the bottom.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 LCD Screen Replacement: passo 8, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 8, imagem 2 %32 Craig CMP801 LCD Screen Replacement: passo 8, imagem 3 %32
      • The battery should only be connected to the LCD by adhesive tape.
      • Using force, carefully remove the battery while holding the LCD in place.
      Pergunte ao FixBot
      Comentar
    1. Craig CMP801 LCD Screen Replacement, LCD Screen: passo 9, imagem 1 %32 Craig CMP801 LCD Screen Replacement, LCD Screen: passo 9, imagem 2 %32 Craig CMP801 LCD Screen Replacement, LCD Screen: passo 9, imagem 3 %32
      • Open the three black flaps located on each side of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Craig CMP801 LCD Screen Replacement: passo 10, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 10, imagem 2 %32
      • Then detach each of the three tabs from the LCD screen.
      Pergunte ao FixBot
      Comentar
    3. Craig CMP801 LCD Screen Replacement: passo 11, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 11, imagem 2 %32
      • Using a Philips 0 Screwdriver, remove the screws connecting the speaker to the motherboard.
      • Remove black plastic speaker holder.
      Pergunte ao FixBot
      Comentar
    4. Craig CMP801 LCD Screen Replacement: passo 12, imagem 1 %32
      • Remove the gray tape connecting the motherboard to the metal slate.
      • Use a spudger to separate the metal slate from the front touch screen.
      Pergunte ao FixBot
      Comentar
    5. Craig CMP801 LCD Screen Replacement: passo 13, imagem 1 %32 Craig CMP801 LCD Screen Replacement: passo 13, imagem 2 %32
      • Carefully slide out the metal slate and LCD screen from underneath the motherboard.
      Pergunte ao FixBot
      Comentar
    6. Craig CMP801 LCD Screen Replacement: passo 14, imagem 1 %32
      • Flip over the metal slate and separate the LCD screen from it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 52
Ao todo: 1,545
