Ir para o conteúdo principal
Cr-48 Chromebook Network Card Replacement
O que você precisa
  1. Cr-48 Chromebook Network Card Replacement, Battery: passo 1, imagem 1 %32 Cr-48 Chromebook Network Card Replacement, Battery: passo 1, imagem 2 %32 Cr-48 Chromebook Network Card Replacement, Battery: passo 1, imagem 3 %32
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    Pergunte ao FixBot
    Comentar
  2. Cr-48 Chromebook Network Card Replacement, Bottom Casing: passo 2, imagem 1 %32 Cr-48 Chromebook Network Card Replacement, Bottom Casing: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    Pergunte ao FixBot
    Comentar
  3. Cr-48 Chromebook Network Card Replacement: passo 3, imagem 1 %32 Cr-48 Chromebook Network Card Replacement: passo 3, imagem 2 %32 Cr-48 Chromebook Network Card Replacement: passo 3, imagem 3 %32
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    Pergunte ao FixBot
    Comentar
  4. Cr-48 Chromebook Network Card Replacement: passo 4, imagem 1 %32 Cr-48 Chromebook Network Card Replacement: passo 4, imagem 2 %32 Cr-48 Chromebook Network Card Replacement: passo 4, imagem 3 %32
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    Pergunte ao FixBot
    Comentar
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: passo 5, imagem 1 %32 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: passo 5, imagem 2 %32 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: passo 5, imagem 3 %32
    • With the lower case removed, look for the network card. It’s typically located in the corner near one of the USB ports.
    • Use tweezers or forceps to carefully lift off the wire connectors attached to the network card.
    • Take note of which wire went to which terminal (e.g., left vs. right).
    Pergunte ao FixBot
    Comentar
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: passo 6, imagem 1 %32 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: passo 6, imagem 2 %32 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: passo 6, imagem 3 %32
    • Remove the single 3 mm screw securing the network card to the board.
    • Once the screw is out, the card should pivot upward slightly (“pop up”).
    • Gently pull the network card out of its socket at an angle and remove it completely.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an E-Waste certified recycler.
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Membros
Autoria de 10 guias
1Comentário do guia
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 1,462
