Ir para o conteúdo principal
Corsair Void Pro RGB Speakers Replacement
O que você precisa
  1. Corsair Void Pro RGB Speakers Replacement, Earcup: passo 1, imagem 1 %32
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Speakers Replacement: passo 2, imagem 1 %32 Corsair Void Pro RGB Speakers Replacement: passo 2, imagem 2 %32
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Speakers Replacement: passo 3, imagem 1 %32 Corsair Void Pro RGB Speakers Replacement: passo 3, imagem 2 %32
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Speakers Replacement, Speakers: passo 4, imagem 1 %32
    • Desolder the wire that connects to the speaker.
    • For steps on how to solder, see this helpful guide.
  5. Corsair Void Pro RGB Speakers Replacement: passo 5, imagem 1 %32 Corsair Void Pro RGB Speakers Replacement: passo 5, imagem 2 %32
    • Use a knife tool as a wedge to remove the speaker and glue in the new speaker.
Conclusão
4 outras pessoas executaram este guia.
Gianna Nobili
Membro desde: 04/15/19
836 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S9-G13, Maness Spring 2019 Membro de Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
Membros da 4
Autoria de 14 guias
5 comentários
Where can i find a new speaker ?
brunodehulster - Responder
The speaker listed in the parts, is not the correct speaker. I purchased them and they are NOT a fit.
ksmith - Responder
Whats the size of the speaker?
smack2k - Responder
The size of the speaker is 50 mm and about 10 mm in depth. I used this speaker in my own repair and it worked well.
noahoryan -
Can u show how to change “Charging Port”??
Jason HKB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Duração total: 3,559
