Ir para o conteúdo principal
Corsair K100 Air Wireless Key Spring Replacement
O que você precisa
    1. Corsair K100 Air Wireless Key Spring Replacement, Key Spring: passo 1, imagem 1 %32 Corsair K100 Air Wireless Key Spring Replacement, Key Spring: passo 1, imagem 2 %32
      • Use a keycap puller to remove each of the affected keys.
      • If you don't have a keycap puller, you can use an opening tool to remove the keys.
      • Key internals should be exposed, showing a right and left metal wing with a spring in the center.
      Pergunte ao FixBot
      Comentar
    2. Corsair K100 Air Wireless Key Spring Replacement: passo 2, imagem 1 %32 Corsair K100 Air Wireless Key Spring Replacement: passo 2, imagem 2 %32 Corsair K100 Air Wireless Key Spring Replacement: passo 2, imagem 3 %32
      • Remove the spring from both metal wings using metal tweezers.
      • The metal wings may come off when removing the spring. To restore, place right wing first, then left wing, back in the key internals using the metal tweezers.
      Pergunte ao FixBot
      Comentar
    3. Corsair K100 Air Wireless Key Spring Replacement: passo 3, imagem 1 %32
      • The key spring is ready for replacement.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 94
Ao todo: 205
