Ir para o conteúdo principal
Corsair Dark Core RGB PRO SE Battery Replacement
O que você precisa
  1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: passo 1, imagem 1 %32 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: passo 1, imagem 2 %32 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: passo 1, imagem 3 %32
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Apply heat with a heat gun or blow dryer to the glide pad near your palm.
    • Carefully remove the glide pad with a spudger.
    • Remove the two screws from beneath the glide pad using a T5 Torx screwdriver.
  2. Corsair Dark Core RGB PRO SE Battery Replacement: passo 2, imagem 1 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 2, imagem 2 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the palm rest by pulling it outwards.
    • Pull up where the latches are.
    • Take your time and work around the area to avoid snapping the plastic latches
    • Remove the top buttons by using tweezers and pushing the tabs.
  3. Corsair Dark Core RGB PRO SE Battery Replacement: passo 3, imagem 1 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 3, imagem 2 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 3, imagem 3 %32
    • Remove the two screws that were underneath the left and right buttons using a Phillips #00 screwdriver.
    • Place the spudger in between the shell and the bottom of the mouse, releasing the latch.
    • Do not try to remove the top shell by pulling it up as it might break the latch.
    • Remove the six screws using a Phillips #00 screwdriver.
  4. Corsair Dark Core RGB PRO SE Battery Replacement: passo 4, imagem 1 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 4, imagem 2 %32 Corsair Dark Core RGB PRO SE Battery Replacement: passo 4, imagem 3 %32
    • Remove the circuit board by pushing the two latches holding it in place in opposite directions.
    • Unplug the ribbon cable by pushing the black connector holding it in place.
    • Disconnect the battery cord by pulling it up.
  5. Corsair Dark Core RGB PRO SE Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery with a spudger or your fingers.
Conclusão
4 outras pessoas executaram este guia.
2 comentários
Where can I buy a spare battery? I don't see them in stores.
Ilya - Responder
I found some models that are compatible on Aliexpress
carlus -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 42
Últimos 30 dias: 191
Duração total: 3,112
