Ir para o conteúdo principal
Core Assembly Removal
O que você precisa
  1. Core Assembly Removal, Opening Procedure: passo 1, imagem 1 %32
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
    Pergunte ao FixBot
    Comentar
  2. Core Assembly Removal: passo 2, imagem 1 %32 Core Assembly Removal: passo 2, imagem 2 %32
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
    Pergunte ao FixBot
    Comentar
  3. Core Assembly Removal: passo 3, imagem 1 %32 Core Assembly Removal: passo 3, imagem 2 %32
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Core Assembly Removal: passo 4, imagem 1 %32 Core Assembly Removal: passo 4, imagem 2 %32
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Core Assembly Removal: passo 5, imagem 1 %32 Core Assembly Removal: passo 5, imagem 2 %32 Core Assembly Removal: passo 5, imagem 3 %32
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
    Pergunte ao FixBot
    Comentar
  6. Core Assembly Removal, Core Assembly Removal: passo 6, imagem 1 %32 Core Assembly Removal, Core Assembly Removal: passo 6, imagem 2 %32
    • Use a spudger to disconnect the display flex cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Core Assembly Removal: passo 7, imagem 1 %32 Core Assembly Removal: passo 7, imagem 2 %32
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
133.802 Reputação
Autoria de 189 guias
Equipe
3Comentários do guia
thanks, loved seeing this watch from the inside!
Crystal Blu - Responder Compartilhar
Great, but now I need to know how to get to the glass to replace it.
selwood.maria - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 72
Ao todo: 4,292
