Ir para o conteúdo principal
Coolpad Defiant Screen Replacement
O que você precisa
  1. Coolpad Defiant Screen Replacement, Back Cover: passo 1, imagem 1 %32 Coolpad Defiant Screen Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
    Pergunte ao FixBot
    Comentar
  2. Coolpad Defiant Screen Replacement: passo 2, imagem 1 %32
    • Remove the back cover from your device.
    Pergunte ao FixBot
    Comentar
  3. Coolpad Defiant Screen Replacement, Battery: passo 3, imagem 1 %32
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
    Pergunte ao FixBot
    Comentar
  4. Coolpad Defiant Screen Replacement, Rear Camera: passo 4, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
    Pergunte ao FixBot
    Comentar
  5. Coolpad Defiant Screen Replacement: passo 5, imagem 1 %32 Coolpad Defiant Screen Replacement: passo 5, imagem 2 %32
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
    Pergunte ao FixBot
    Comentar
  6. Coolpad Defiant Screen Replacement: passo 6, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
    Pergunte ao FixBot
    Comentar
  7. Coolpad Defiant Screen Replacement: passo 7, imagem 1 %32 Coolpad Defiant Screen Replacement: passo 7, imagem 2 %32 Coolpad Defiant Screen Replacement: passo 7, imagem 3 %32
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
    Pergunte ao FixBot
    Comentar
  8. Coolpad Defiant Screen Replacement: passo 8, imagem 1 %32 Coolpad Defiant Screen Replacement: passo 8, imagem 2 %32 Coolpad Defiant Screen Replacement: passo 8, imagem 3 %32
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
    Pergunte ao FixBot
    Comentar
  9. Coolpad Defiant Screen Replacement: passo 9, imagem 1 %32
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
    Pergunte ao FixBot
    Comentar
  10. Coolpad Defiant Screen Replacement, Screen: passo 10, imagem 1 %32 Coolpad Defiant Screen Replacement, Screen: passo 10, imagem 2 %32
    • Using the plastic pry tool, remove the lower logic board, starting with the removal of the vibrator and working across the board.
    • The board is held down by adhesives, so force is required to remove it.
    • Since the board is fragile, be careful when removing the board.
    Pergunte ao FixBot
    Comentar
  11. Coolpad Defiant Screen Replacement: passo 11, imagem 1 %32
    • Place the suction cup tool on the bottom left corner of the screen.
    Pergunte ao FixBot
    Comentar
  12. Coolpad Defiant Screen Replacement: passo 12, imagem 1 %32
    • Pull straight up on the suction cup to pop the screen off.
    • Some heat may need to be applied to loosen the adhesive. Use a hair dryer or heat gun. This device was easy pulled apart without heat tho.
    • Be sure to lift the bottom of the screen up. Be careful of the cables on the top of the screen.
    Pergunte ao FixBot
    Comentar
  13. Coolpad Defiant Screen Replacement: passo 13, imagem 1 %32
    • Once the screen is free from the adhesive, slide the flex cable through the middle chassis assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
1Comentário do guia
I never even heard of this website till today I think it's awesome I'm wondering is there like a program or a thing set up to where I can mail my phone and pay someone to do it for me because I'm like extremely heavy-handed and I'm clumsy I trip up steps so I know and there's a 13 directions I seen the word careful a whole lot and pull easy and I've already have an anxiety just thinking about me doing it let alone actually doing it so is there any way someone can help me
Crystal Tyson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 3,680
