Ir para o conteúdo principal
Contour Roam2 Waterproof Action Camera Record Slider Replacement
O que você precisa
    1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: passo 1, imagem 1 %32
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Pergunte ao FixBot
      Comentar
    2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 2, imagem 1 %32 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 2, imagem 2 %32
      • Rotate the metal ring counterclockwise until completely removed.
      Pergunte ao FixBot
      Comentar
    3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 3, imagem 1 %32 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 3, imagem 2 %32
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      Pergunte ao FixBot
      Comentar
    4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, imagem 1 %32 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, imagem 2 %32 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, imagem 3 %32
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      Pergunte ao FixBot
      Comentar
    5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 5, imagem 1 %32
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
2Comentários do guia
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - Responder Compartilhar
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 1,436
