Ir para o conteúdo principal
Contour Roam2 Back Door Replacement
O que você precisa
    1. Contour Roam2 Back Door Replacement, Record Slider: passo 1, imagem 1 %32
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Pergunte ao FixBot
      Comentar
    2. Contour Roam2 Back Door Replacement: passo 2, imagem 1 %32 Contour Roam2 Back Door Replacement: passo 2, imagem 2 %32
      • Rotate the metal ring counterclockwise until completely removed.
      Pergunte ao FixBot
      Comentar
    3. Contour Roam2 Back Door Replacement: passo 3, imagem 1 %32 Contour Roam2 Back Door Replacement: passo 3, imagem 2 %32
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      Pergunte ao FixBot
      Comentar
    4. Contour Roam2 Back Door Replacement: passo 4, imagem 1 %32 Contour Roam2 Back Door Replacement: passo 4, imagem 2 %32 Contour Roam2 Back Door Replacement: passo 4, imagem 3 %32
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      Pergunte ao FixBot
      Comentar
    5. Contour Roam2 Back Door Replacement: passo 5, imagem 1 %32
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      Pergunte ao FixBot
      Comentar
    1. Contour Roam2 Back Door Replacement, Mounting Piece: passo 6, imagem 1 %32 Contour Roam2 Back Door Replacement, Mounting Piece: passo 6, imagem 2 %32
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      Pergunte ao FixBot
      Comentar
    2. Contour Roam2 Back Door Replacement: passo 7, imagem 1 %32 Contour Roam2 Back Door Replacement: passo 7, imagem 2 %32
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      Pergunte ao FixBot
      Comentar
    3. Contour Roam2 Back Door Replacement: passo 8, imagem 1 %32
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      Pergunte ao FixBot
      Comentar
    4. Contour Roam2 Back Door Replacement: passo 9, imagem 1 %32 Contour Roam2 Back Door Replacement: passo 9, imagem 2 %32
      • Remove and replace mount piece.
      Pergunte ao FixBot
      Comentar
    1. Contour Roam2 Back Door Replacement, Back Door: passo 10, imagem 1 %32
      • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
      • After removing the metal bar, the spring will become loose and may fall out on its own.
      Pergunte ao FixBot
      Comentar
    2. Contour Roam2 Back Door Replacement: passo 11, imagem 1 %32
      • Remove and replace back door.
      • Door should easily be removed by pulling away from main body of camera.
      • As door is being pulled away, the spring may fall out own its own.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jamie Maple
Membro desde: 03/11/15
310 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 2,199
