Ir para o conteúdo principal
Connect Four Electronic Handheld Back Casing Replacement
O que você precisa
    1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: passo 1, imagem 1 %32
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Pergunte ao FixBot
      Comentar
    2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, imagem 1 %32 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, imagem 2 %32
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, imagem 1 %32 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, imagem 2 %32
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Wil
Membro desde: 10/22/14
313 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 8-11, Williams Fall 2014 Membro de Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 490
