Ir para o conteúdo principal
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
O que você precisa
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, imagem 1 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, imagem 2 %32
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, imagem 1 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, imagem 2 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, imagem 3 %32
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, imagem 1 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, imagem 2 %32
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, imagem 1 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, imagem 2 %32 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, imagem 3 %32
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: passo 6, imagem 1 %32
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 7, imagem 1 %32
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
Conclusão
Timothy Lo
Membro desde: 04/22/14
1.172 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-58, Amido Spring 2014 Membro de Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
Membros da 4
Autoria de 7 guias
2 comentários
so where do you buy parts???
akatser1 - Responder
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 4,484
