Ir para o conteúdo principal
Computer RAM Replacement
O que você precisa
  1. Computer RAM Replacement, RAM: passo 1, imagem 1 %32
    • Press the power button on the case of your PC to turn it off.
    Pergunte ao FixBot
    Comentar
  2. Computer RAM Replacement: passo 2, imagem 1 %32
    • Turn off the computer from the power supply in the back, and unplug the cable from the PSU.
    • This step is important as not doing so means the computer is still receiving power and can damage your computer parts or even shock you.
    Pergunte ao FixBot
    Comentar
  3. Computer RAM Replacement: passo 3, imagem 1 %32
    • Lay the case on its side.
    • For this case model (Cooler Master TD 500 Mesh) it has two thumb screws on the top corners which can be removed with your fingers.
    • Remove the side panel.
    Pergunte ao FixBot
    Comentar
  4. Computer RAM Replacement: passo 4, imagem 1 %32
    • Your RAM sticks are the two long cards with T-FORCE written on the top of them.
    Pergunte ao FixBot
    Comentar
  5. Computer RAM Replacement: passo 5, imagem 1 %32 Computer RAM Replacement: passo 5, imagem 2 %32 Computer RAM Replacement: passo 5, imagem 3 %32
    • Each motherboard is different. This motherboard (MSI B450 Gaming Plus Max) has two pull tabs on each side. Push down on them to release each card.
    • If you are not using this motherboard, your motherboard may only have one pull tab instead of one on each side. Please refer to the manual for your motherboard.
    Pergunte ao FixBot
    Comentar
  6. Computer RAM Replacement: passo 6, imagem 1 %32
    • Once the pull tabs are released, remove the RAM from the RAM slots and set to the side.
    Pergunte ao FixBot
    Comentar
  7. Computer RAM Replacement: passo 7, imagem 1 %32 Computer RAM Replacement: passo 7, imagem 2 %32 Computer RAM Replacement: passo 7, imagem 3 %32
    • Repeat Steps 5 & 6 to remove the second RAM card from the RAM slot.
    • If you only have one RAM card, skip to the next step.
    Pergunte ao FixBot
    Comentar
  8. Computer RAM Replacement: passo 8, imagem 1 %32 Computer RAM Replacement: passo 8, imagem 2 %32
    • To install new RAM, line up the notch of the RAM slot with the notch of the RAM slot on the motherboard.
    • For this motherboard, insert the RAM in the 2nd slot from left to right and the furthest one to the right.
    Pergunte ao FixBot
    Comentar
  9. Computer RAM Replacement: passo 9, imagem 1 %32 Computer RAM Replacement: passo 9, imagem 2 %32
    • Push down with even pressure on both sides until you hear two clicks since on this motherboard there are two tabs, one on each side.
    Pergunte ao FixBot
    Comentar
  10. Computer RAM Replacement: passo 10, imagem 1 %32
    • Repeat Steps 8 and 9 to install the second RAM stick.
    Pergunte ao FixBot
    Comentar
  11. Computer RAM Replacement: passo 11, imagem 1 %32 Computer RAM Replacement: passo 11, imagem 2 %32
    • Power your PC by turning on the power switch on the back.
    • Press the power button on the top of the case.
    Pergunte ao FixBot
    Comentar
  12. Computer RAM Replacement: passo 12, imagem 1 %32 Computer RAM Replacement: passo 12, imagem 2 %32
    • Stand your computer back up.
    • See if the computer powers up and into windows and shows up on your display. If it does, put the side panel back on.
    • If you do not see anything on your monitor’s display, you did not install the RAM correctly and must check to see if it's fully secured. Remove the RAM again and install again.
    Pergunte ao FixBot
    Comentar
  13. Computer RAM Replacement: passo 13, imagem 1 %32 Computer RAM Replacement: passo 13, imagem 2 %32
    • Check to see if your RAM is running at its rated speed.
    • Restart your PC and spam click your delete key on your keyboard until you get into the MSI BIOS.
    Pergunte ao FixBot
    Comentar
  14. Computer RAM Replacement: passo 14, imagem 1 %32 Computer RAM Replacement: passo 14, imagem 2 %32
    • You will know you got into your BIOS if see a screen like this. On the top section, for this RAM, it should say the DDR speed is 3200 Mhz. If you do see this, skip to the final step.
    • If you do not, with your arrow keys go to the OC section, scroll to DRAM frequency and instead of auto, select the rated speed of your RAM. (Don't forget to save this setting.)
    Pergunte ao FixBot
    Comentar
  15. Computer RAM Replacement: passo 15, imagem 1 %32
    • Press your Esc key until the message in the picture pops out. Navigate to exit and your PC should restart and you are good to go. You have successfully remove and replaced or upgraded your RAM!
    • Navigate to "Exit," and your PC will restart. You are good to go!
    Pergunte ao FixBot
    Comentar
Conclusão
This is how you replace/repair your RAM, and how to check it is running at the rated speed.
3 outras pessoas executaram este guia.
Equipe
Texas Tech, Team S14-G8, Cowan Fall 2020 Membro de Texas Tech, Team S14-G8, Cowan Fall 2020
TTU-COWAN-F20S14G8
2 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 136
Ao todo: 5,045
