Ir para o conteúdo principal
Computer King Muffin Kinder 7 Logic Board Replacement
O que você precisa
  1. Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: passo 1, imagem 2 %32
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Logic Board Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Logic Board Replacement: passo 3, imagem 1 %32 Computer King Muffin Kinder 7 Logic Board Replacement: passo 3, imagem 2 %32
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Logic Board Replacement: passo 4, imagem 1 %32
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, imagem 1 %32 Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, imagem 2 %32 Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, imagem 3 %32
    • Unsolder the 11 red, back, and grey wires connected to the logic board.
    • Tips on how to solder can be found here.
  6. Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, imagem 1 %32 Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, imagem 2 %32 Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, imagem 3 %32
    • Use the flat end of the spudger to lift the black panels covering the three ribbon cables connected to the logic board.
  7. Computer King Muffin Kinder 7 Logic Board Replacement: passo 7, imagem 1 %32
    • Pull the three ribbon cables out so that they are no longer connected to the logic board.
Conclusão
Uma outra pessoa concluiu este guia.
Katherine
Membro desde: 01/22/15
439 Reputação
Autoria de 3 guias
Equipe
UWT Liner: Group 2 Membro de UWT Liner: Group 2
Community
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 387
