Ir para o conteúdo principal
Compaq Mini 110 Top Cover Replacement
O que você precisa
    1. Compaq Mini 110 Top Cover Replacement, Battery: passo 1, imagem 1 %32 Compaq Mini 110 Top Cover Replacement, Battery: passo 1, imagem 2 %32
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Pergunte ao FixBot
      Comentar
    2. Compaq Mini 110 Top Cover Replacement: passo 2, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 2, imagem 2 %32 Compaq Mini 110 Top Cover Replacement: passo 2, imagem 3 %32
      • Push both tabs inward simultaneously and slide the battery out.
      Pergunte ao FixBot
      Comentar
    1. Compaq Mini 110 Top Cover Replacement, RAM: passo 3, imagem 1 %32 Compaq Mini 110 Top Cover Replacement, RAM: passo 3, imagem 2 %32
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Pergunte ao FixBot
      Comentar
    2. Compaq Mini 110 Top Cover Replacement: passo 4, imagem 1 %32
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Pergunte ao FixBot
      Comentar
    1. Compaq Mini 110 Top Cover Replacement, Keyboard: passo 5, imagem 1 %32 Compaq Mini 110 Top Cover Replacement, Keyboard: passo 5, imagem 2 %32
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Pergunte ao FixBot
      Comentar
    2. Compaq Mini 110 Top Cover Replacement: passo 6, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 6, imagem 2 %32
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Pergunte ao FixBot
      Comentar
    3. Compaq Mini 110 Top Cover Replacement: passo 7, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 7, imagem 2 %32
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Pergunte ao FixBot
      Comentar
    4. Compaq Mini 110 Top Cover Replacement: passo 8, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 8, imagem 2 %32
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Compaq Mini 110 Top Cover Replacement, Hard Drive: passo 9, imagem 1 %32
      • Remove the three screws holding the panel in place.
      Pergunte ao FixBot
      Comentar
    2. Compaq Mini 110 Top Cover Replacement: passo 10, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 10, imagem 2 %32
      • Pull up on the tab to remove the hard drive.
      Pergunte ao FixBot
      Comentar
    1. Compaq Mini 110 Top Cover Replacement, Top Cover: passo 11, imagem 1 %32
      • Remove the eight screws that are from the plastic top cover.
      Pergunte ao FixBot
      Comentar
    2. Compaq Mini 110 Top Cover Replacement: passo 12, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 12, imagem 2 %32 Compaq Mini 110 Top Cover Replacement: passo 12, imagem 3 %32
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Pergunte ao FixBot
      Comentar
    3. Compaq Mini 110 Top Cover Replacement: passo 13, imagem 1 %32 Compaq Mini 110 Top Cover Replacement: passo 13, imagem 2 %32
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
alea
Membro desde: 10/06/10
1.429 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 22-2, Maness Fall 2010 Membro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membros
Autoria de 122 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 8,730
