Ir para o conteúdo principal
Compaq Evo N1000v Rear Fan Replacement
O que você precisa
    1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: passo 1, imagem 1 %32
      • Carefully remove the screws located inside the red circles.
      Pergunte ao FixBot
      Comentar
    2. Compaq Evo N1000v Rear Fan Replacement: passo 2, imagem 1 %32 Compaq Evo N1000v Rear Fan Replacement: passo 2, imagem 2 %32
      • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
      • Push down on the spudger to lift the LED display upward.
      • Do this on both the left and right sides of the device as shown in the images.
      Pergunte ao FixBot
      Comentar
    3. Compaq Evo N1000v Rear Fan Replacement: passo 3, imagem 1 %32
      • Completely remove the LED display panel from the device.
      Pergunte ao FixBot
      Comentar
    4. Compaq Evo N1000v Rear Fan Replacement: passo 4, imagem 1 %32
      • Lift the keyboard up from the back end as shown in the image.
      Pergunte ao FixBot
      Comentar
    5. Compaq Evo N1000v Rear Fan Replacement: passo 5, imagem 1 %32
      • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
      Pergunte ao FixBot
      Comentar
    6. Compaq Evo N1000v Rear Fan Replacement: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
      • Repeat this action on the right side of the lock.
      Pergunte ao FixBot
      Comentar
    7. Compaq Evo N1000v Rear Fan Replacement: passo 7, imagem 1 %32
      • Pull the keyboard upward to remove it from the device.
      Pergunte ao FixBot
      Comentar
    8. Compaq Evo N1000v Rear Fan Replacement: passo 8, imagem 1 %32
      • Unscrew the 3 screws as shown in the photo.
      Pergunte ao FixBot
      Comentar
    9. Compaq Evo N1000v Rear Fan Replacement: passo 9, imagem 1 %32
      • Remove the cable with the grip tweezers as shown in the photo.
      Pergunte ao FixBot
      Comentar
    10. Compaq Evo N1000v Rear Fan Replacement: passo 10, imagem 1 %32
      • Remove the rear fan.
      • Repeat these steps in reverse order to install the new rear fan.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
ryan
Membro desde: 03/12/14
470 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 818
