Ir para o conteúdo principal
Compaq Evo N1000v Keyboard Replacement
O que você precisa
  1. Compaq Evo N1000v Keyboard Replacement, LED Cover: passo 1, imagem 1 %32
    • Flip the laptop over with the rear panel facing forward.
    Pergunte ao FixBot
    Comentar
  2. Compaq Evo N1000v Keyboard Replacement: passo 2, imagem 1 %32
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
    Pergunte ao FixBot
    Comentar
  3. Compaq Evo N1000v Keyboard Replacement: passo 3, imagem 1 %32
    • Flip the laptop back over with the front facing forward. Open the screen.
    Pergunte ao FixBot
    Comentar
  4. Compaq Evo N1000v Keyboard Replacement: passo 4, imagem 1 %32
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
    Pergunte ao FixBot
    Comentar
  5. Compaq Evo N1000v Keyboard Replacement: passo 5, imagem 1 %32
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    Pergunte ao FixBot
    Comentar
  6. Compaq Evo N1000v Keyboard Replacement: passo 6, imagem 1 %32
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
    Pergunte ao FixBot
    Comentar
  7. Compaq Evo N1000v Keyboard Replacement: passo 7, imagem 1 %32
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    Pergunte ao FixBot
    Comentar
  8. Compaq Evo N1000v Keyboard Replacement: passo 8, imagem 1 %32 Compaq Evo N1000v Keyboard Replacement: passo 8, imagem 2 %32
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
    Pergunte ao FixBot
    Comentar
  9. Compaq Evo N1000v Keyboard Replacement, Keyboard: passo 9, imagem 1 %32
    • Lift the back edge of the keyboard and pull towards the screen.
    Pergunte ao FixBot
    Comentar
  10. Compaq Evo N1000v Keyboard Replacement: passo 10, imagem 1 %32
    • Pull the cable and lift up to release.
    Pergunte ao FixBot
    Comentar
  11. Compaq Evo N1000v Keyboard Replacement: passo 11, imagem 1 %32
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
kim
Membro desde: 04/14/10
77 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 29-74, Johann Spring 2010 Membro de Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 4,145
