Ir para o conteúdo principal
Compaq Evo N1000v Floppy Drive Replacement
O que você precisa
    1. Compaq Evo N1000v Floppy Drive Replacement, LED Cover: passo 1, imagem 1 %32
      • Flip the laptop over with the rear panel facing forward.
      Pergunte ao FixBot
      Comentar
    2. Compaq Evo N1000v Floppy Drive Replacement: passo 2, imagem 1 %32
      • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
      Pergunte ao FixBot
      Comentar
    3. Compaq Evo N1000v Floppy Drive Replacement: passo 3, imagem 1 %32
      • Flip the laptop back over with the front facing forward. Open the screen.
      Pergunte ao FixBot
      Comentar
    4. Compaq Evo N1000v Floppy Drive Replacement: passo 4, imagem 1 %32
      • Locate the F1 and F2 keys near the top left corner of the keyboard.
      Pergunte ao FixBot
      Comentar
    5. Compaq Evo N1000v Floppy Drive Replacement: passo 5, imagem 1 %32
      • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Pergunte ao FixBot
      Comentar
    6. Compaq Evo N1000v Floppy Drive Replacement: passo 6, imagem 1 %32
      • Locate the Scroll and Pause keys near the top right corner of the keyboard.
      Pergunte ao FixBot
      Comentar
    7. Compaq Evo N1000v Floppy Drive Replacement: passo 7, imagem 1 %32
      • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Pergunte ao FixBot
      Comentar
    8. Compaq Evo N1000v Floppy Drive Replacement: passo 8, imagem 1 %32 Compaq Evo N1000v Floppy Drive Replacement: passo 8, imagem 2 %32
      • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
      Pergunte ao FixBot
      Comentar
    1. Compaq Evo N1000v Floppy Drive Replacement, Keyboard: passo 9, imagem 1 %32
      • Lift the back edge of the keyboard and pull towards the screen.
      Pergunte ao FixBot
      Comentar
    2. Compaq Evo N1000v Floppy Drive Replacement: passo 10, imagem 1 %32
      • Pull the cable and lift up to release.
      Pergunte ao FixBot
      Comentar
    3. Compaq Evo N1000v Floppy Drive Replacement: passo 11, imagem 1 %32
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. Compaq Evo N1000v Floppy Drive Replacement, Palm Rest: passo 12, imagem 1 %32
      • Close the laptop and flip it so the rear panel is facing up.
      Pergunte ao FixBot
      Comentar
    2. Compaq Evo N1000v Floppy Drive Replacement: passo 13, imagem 1 %32
      • Using the TR8 Torx screwdriver, remove the six screws from the back case.
      Pergunte ao FixBot
      Comentar
    3. Compaq Evo N1000v Floppy Drive Replacement: passo 14, imagem 1 %32
      • Remove the battery.
      • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
      • Flip the laptop over again so the top is facing up.
      • Open the laptop screen and face it towards you.
      Pergunte ao FixBot
      Comentar
    4. Compaq Evo N1000v Floppy Drive Replacement: passo 15, imagem 1 %32
      • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
      • Be gentle as it is connected by some cables.
      Pergunte ao FixBot
      Comentar
    5. Pergunte ao FixBot
      Comentar
    6. Compaq Evo N1000v Floppy Drive Replacement: passo 17, imagem 1 %32
      • Disconnect the second ribbon cable.
      Pergunte ao FixBot
      Comentar
    7. Compaq Evo N1000v Floppy Drive Replacement: passo 18, imagem 1 %32
      • Remove the palm rest.
      Pergunte ao FixBot
      Comentar
      • Locate and remove the three screws shown in picture.
      Pergunte ao FixBot
      Comentar
    1. Compaq Evo N1000v Floppy Drive Replacement: passo 20, imagem 1 %32
      • Lift up and remove floppy drive from the palm rest.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Equipe
Cal Poly, Team 29-74, Johann Spring 2010 Membro de Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Membros
Autoria de 49 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 29
Ao todo: 3,838
