Ir para o conteúdo principal
Commodore 64 3AG fuse Replacement
O que você precisa
    1. Commodore 64 3AG fuse Replacement, Removing screws: passo 1, imagem 1 %32 Commodore 64 3AG fuse Replacement, Removing screws: passo 1, imagem 2 %32 Commodore 64 3AG fuse Replacement, Removing screws: passo 1, imagem 3 %32
      • 1. Remove three 6.75mm ph2 screw heads from the casing
      Pergunte ao FixBot
      Comentar
    2. Commodore 64 3AG fuse Replacement, Opening: passo 2, imagem 1 %32 Commodore 64 3AG fuse Replacement, Opening: passo 2, imagem 2 %32
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      Pergunte ao FixBot
      Comentar
    1. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: passo 3, imagem 1 %32 Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: passo 3, imagem 2 %32
      • 1. Detach the multi-colored wire bundles that's connected to the motherboard
      • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
      Pergunte ao FixBot
      Comentar
    2. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: passo 4, imagem 1 %32
      • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
      Pergunte ao FixBot
      Comentar
    3. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: passo 5, imagem 1 %32 Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: passo 5, imagem 2 %32
      • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
      • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 13-6, Staggers Fall 2014 Membro de USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Membros
Autoria de 25 guias
2Comentários do guia
The fuse is 1.5 Amp, not 3
JC Andy - Responder Compartilhar
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
Toon Konings - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 4,861
