Ir para o conteúdo principal
ColecoVision Power Switch Replacement
O que você precisa
  1. ColecoVision Power Switch Replacement, Power Switch: passo 1, imagem 1 %32
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Power Switch Replacement: passo 2, imagem 1 %32 ColecoVision Power Switch Replacement: passo 2, imagem 2 %32
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Power Switch Replacement: passo 3, imagem 1 %32
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
  4. ColecoVision Power Switch Replacement: passo 4, imagem 1 %32 ColecoVision Power Switch Replacement: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Power Switch Replacement: passo 5, imagem 1 %32
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
  6. ColecoVision Power Switch Replacement: passo 6, imagem 1 %32
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Bobby
Membro desde: 10/17/18
380 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro de UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 1,730
