Ir para o conteúdo principal
ColecoVision Cartridge Reader Replacement
O que você precisa
  1. ColecoVision Cartridge Reader Replacement, Cartridge Reader: passo 1, imagem 1 %32
    • Flip the console upside down and remove the eight 15mm Phillips #1 screws.
  2. ColecoVision Cartridge Reader Replacement: passo 2, imagem 1 %32 ColecoVision Cartridge Reader Replacement: passo 2, imagem 2 %32
    • Use the metal spudger along the bottom rim of the front panel to safely remove the top of the console. Set aside the top.
  3. ColecoVision Cartridge Reader Replacement: passo 3, imagem 1 %32 ColecoVision Cartridge Reader Replacement: passo 3, imagem 2 %32
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Remove the casing to reveal the cartridge reader.
  4. ColecoVision Cartridge Reader Replacement: passo 4, imagem 1 %32 ColecoVision Cartridge Reader Replacement: passo 4, imagem 2 %32 ColecoVision Cartridge Reader Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Desolder the sides of the cartridge reader using the soldering iron and desolder pump.
    • Refer to this soldering technique guide for reference
    • Patiently wait for the cartridge reader to cool down after being desoldered.
    • It's very important to remove all the tin from the motherboard and cartridge reader before lifting it from the motherboard. Failure to do so could damage the motherboard.
    • Carefully lift up the cartridge reader. A plastic spudger might be helpful in order to easily remove the cartridge reader.
Conclusão
Anastazia Kidder
Membro desde: 10/17/18
109 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro de UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 1,580
