Ir para o conteúdo principal
Coby Kyros MID9042 Speakers Replacement
O que você precisa
  1. Coby Kyros MID9042 Speakers Replacement, Speakers: passo 1, imagem 1 %32 Coby Kyros MID9042 Speakers Replacement, Speakers: passo 1, imagem 2 %32
    • Remove the Anti-slip pads from all four corners of the back of the device.
    • Use Phillips #0 Precision screwdriver to remove the four screws from the back cover (screws are about 1/8'').
  2. Coby Kyros MID9042 Speakers Replacement: passo 2, imagem 1 %32 Coby Kyros MID9042 Speakers Replacement: passo 2, imagem 2 %32 Coby Kyros MID9042 Speakers Replacement: passo 2, imagem 3 %32
    • Potential for device damage. Be careful not to break the inner plastic tabs while pulling the back cover off.
    • Gently use the iFixit opening tool to pry the back cover apart from the front.
    • After you have opened the cover, use your hands to open the tablet like a book.
  3. Coby Kyros MID9042 Speakers Replacement: passo 3, imagem 1 %32 Coby Kyros MID9042 Speakers Replacement: passo 3, imagem 2 %32
    • Desolder the red and black speaker wires from the circuit board. Como soldar e dessoldar contatos
    • Gently remove the speakers from the tablet.
    • When replacing the speaker, remember the red wire connects to positive and the black wire connects to negative.
Conclusão
Samantha Rollings
Membro desde: 03/30/15
349 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-6, Shastany Spring 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 416
