Ir para o conteúdo principal
Coby KYROS MID7125 Side Lock Button Replacement
O que você precisa
  1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: passo 1, imagem 1 %32
    • Begin by removing back panel using the large opening tool.
  2. Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 1 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 2 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 3 %32
    • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
  3. Coby KYROS MID7125 Side Lock Button Replacement: passo 3, imagem 1 %32
    • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
    • Review Battery Replacement for details on how to remove battery.
  4. Coby KYROS MID7125 Side Lock Button Replacement: passo 4, imagem 1 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 4, imagem 2 %32
    • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
  5. Coby KYROS MID7125 Side Lock Button Replacement: passo 5, imagem 1 %32
    • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
    • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
  6. Coby KYROS MID7125 Side Lock Button Replacement: passo 6, imagem 1 %32
    • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
    • Reverse steps 1-5 to reassemble.
Conclusão
Benjamin Foley
Membro desde: 10/20/16
125 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
Membros da 3
Autoria de 10 guias
Um comentário
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 189
