Ir para o conteúdo principal
Coby KYROS MID7125 Motherboard Replacement
O que você precisa
  1. Coby KYROS MID7125 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel
  2. Coby KYROS MID7125 Motherboard Replacement: passo 2, imagem 1 %32 Coby KYROS MID7125 Motherboard Replacement: passo 2, imagem 2 %32 Coby KYROS MID7125 Motherboard Replacement: passo 2, imagem 3 %32
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
  3. Coby KYROS MID7125 Motherboard Replacement: passo 3, imagem 1 %32 Coby KYROS MID7125 Motherboard Replacement: passo 3, imagem 2 %32 Coby KYROS MID7125 Motherboard Replacement: passo 3, imagem 3 %32
    • Desolder 2 speaker wires
    • Desolder antenna wire
    • Desolder microphone wire
    • Remove all wires you just desoldered.
  4. Coby KYROS MID7125 Motherboard Replacement: passo 4, imagem 1 %32
    • Desolder the battery wires.
    • If soldering is new to you, then check out this useful guide on soldering and desoldering connections.
    • Remove the battery.
  5. Coby KYROS MID7125 Motherboard Replacement: passo 5, imagem 1 %32
    • Unscrew 4 screws connecting around mother board using the J0 Phillips head screwdriver.
  6. Coby KYROS MID7125 Motherboard Replacement: passo 6, imagem 1 %32 Coby KYROS MID7125 Motherboard Replacement: passo 6, imagem 2 %32
    • Use plastic spudger to take off motherboard by lifting off right hand side and pulling sideways.
Conclusão
Nicole Connelly
Membro desde: 10/20/16
1 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 269
