Ir para o conteúdo principal
Coby DVD-R11000 3-Pin Power Cable Replacement
O que você precisa
    1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, imagem 1 %32 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, imagem 2 %32 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, imagem 3 %32
      • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
      • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
      • It is not required to remove the other seven screws in the middle between the I/O ports.
      Pergunte ao FixBot
      Comentar
    2. Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, imagem 1 %32 Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, imagem 2 %32 Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, imagem 3 %32
      • Position the DVD player so that the back is facing you
      • Grab underneath the sides of the DVD player and lift the front of it upwards.
      • Carefully pull the top of the casing off
      Pergunte ao FixBot
      Comentar
    1. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: passo 3, imagem 1 %32 Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: passo 3, imagem 2 %32
      • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
      • Remove the wire from the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Andrew
Membro desde: 10/22/14
501 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 689
