Ir para o conteúdo principal
Cobra 29 LTD Classic Power Port Replacement
O que você precisa
  1. Cobra 29 LTD Classic Power Port Replacement, Power Cable: passo 1, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement, Power Cable: passo 1, imagem 2 %32
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Power Port Replacement: passo 2, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 2, imagem 2 %32
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Power Port Replacement, Antenna Cable: passo 3, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement, Antenna Cable: passo 3, imagem 2 %32
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Power Port Replacement: passo 4, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 4, imagem 2 %32
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Power Port Replacement, Microphone: passo 5, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement, Microphone: passo 5, imagem 2 %32
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Power Port Replacement: passo 6, imagem 1 %32
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Power Port Replacement, Outer Cover: passo 7, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement, Outer Cover: passo 7, imagem 2 %32
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Power Port Replacement: passo 8, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 8, imagem 2 %32 Cobra 29 LTD Classic Power Port Replacement: passo 8, imagem 3 %32
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Power Port Replacement: passo 9, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 9, imagem 2 %32 Cobra 29 LTD Classic Power Port Replacement: passo 9, imagem 3 %32
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Power Port Replacement: passo 10, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 10, imagem 2 %32
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Power Port Replacement: passo 11, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 11, imagem 2 %32 Cobra 29 LTD Classic Power Port Replacement: passo 11, imagem 3 %32
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
  12. Cobra 29 LTD Classic Power Port Replacement, Power Port: passo 12, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement, Power Port: passo 12, imagem 2 %32 Cobra 29 LTD Classic Power Port Replacement, Power Port: passo 12, imagem 3 %32
    • De-solder the yellow wire that is connected to the power port, with a soldering iron and the desoldering wick.
    • During reassembly you will need to resolder the components back together.
  13. Cobra 29 LTD Classic Power Port Replacement: passo 13, imagem 1 %32
    • The wire may still be hot, so let it sit for 30 seconds before continuing.
    • Remove the yellow wire from the power port.
  14. Cobra 29 LTD Classic Power Port Replacement: passo 14, imagem 1 %32
    • De-solder the black wire that is connected to the power port, with a soldering iron and the desoldering wick.
  15. Cobra 29 LTD Classic Power Port Replacement: passo 15, imagem 1 %32
    • Remove the black wire from the power port.
  16. Cobra 29 LTD Classic Power Port Replacement: passo 16, imagem 1 %32
    • Unscrew the two 6mm Phillips screws counterclockwise, using a #1 Phillips head screwdriver.
    • If screws have lock-tight glue on them, use a strong force to initially remove the screws from the device.
  17. Cobra 29 LTD Classic Power Port Replacement: passo 17, imagem 1 %32 Cobra 29 LTD Classic Power Port Replacement: passo 17, imagem 2 %32
    • Gently pull the power port out of the case.
Conclusão
Noah Negrey
Membro desde: 10/13/13
349 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-37, Amido Fall 2013 Membro de Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
Membros da 4
Autoria de 9 guias
4 comentários
Difficulty Difficult? this is the easiest thing you can do to one of these radios.
bassblaster505 - Responder
thank you, i’m hoping this will help but i doubt it, i had too big of a fuse in mine and it took a spike hit and lost all power a few years back but i’d really like to get this fixed.
BOB MCMILLAN - Responder
Any idea what the board pin hole number is that the black cord from the negative goes into? I’ve got a 2018 29 LX
Keith Nicola - Responder
Not sure. There is a partial schematic available at www.cbtricks.com
Tom Capehart -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 44
Duração total: 6,561
