Ir para o conteúdo principal
Cleaning the Fan Blades
O que você precisa
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): passo 1, imagem 1 %32
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Cleaning the Fan Blades: passo 2, imagem 1 %32
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
    Pergunte ao FixBot
    Comentar
  3. Cleaning the Fan Blades: passo 3, imagem 1 %32
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Cleaning the Fan Blades: passo 4, imagem 1 %32
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    Pergunte ao FixBot
    Comentar
  5. Cleaning the Fan Blades: passo 5, imagem 1 %32 Cleaning the Fan Blades: passo 5, imagem 2 %32
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
    Pergunte ao FixBot
    Comentar
  6. Cleaning the Fan Blades, Fan Blades: passo 6, imagem 1 %32
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 82
Ao todo: 11,544
