Introdução
This guide will show you how to replace the fan belt in a Clarke EZ-8 floor sander.
O que você precisa
Passo 1 Disconnect all power cables
Cuidado: a etapa 1 é proveniente de um guia marcado como em andamento.
Use a long Phillips #2 screwdriver to remove the two screws securing the belt guard:
One 1/4-20 x 18 mm screw
One 1/4-20 x 30 mm screw
Carefully tilt the floor sander onto its side, exposing the sanding drum and the dust shoe plate.
Use a Phillips #2 screwdriver to remove the four screws on the underside of the sander securing the dust shoe plate.
Remove the dust shoe plate.
For the purposes of this repair, there is no need to fully remove any of the nuts in the following steps. Just loosen them enough to allow the motor to slide back and forth.
Slide the motor along its mounting slots toward the back of the sander until the fan belt is detensioned.
3 outras pessoas executaram este guia.
