Ir para o conteúdo principal
Clarke Floor Buffer 01278A 2016 Rotor Replacement
O que você precisa
  1. Clarke Floor Buffer 01278A 2016 Rotor Replacement, Preparation: passo 1, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement, Preparation: passo 1, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement, Preparation: passo 1, imagem 3 %32
    • Before you begin, make sure the floor buffer is turned off and unplugged.
    • Brace the back of the floor buffer with your foot near the wheel axle and grasp the handle with both hands.
    • Slowly tilt the floor buffer back until the handle rests on your work surface.
  2. Clarke Floor Buffer 01278A 2016 Rotor Replacement, Remove the Shield Brush: passo 2, imagem 1 %32
    • Use a 3/16" hex key or driver bit to remove the four 18.6 mm-long screws securing the shield brush to the bottom of the floor buffer.
  3. Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 3, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 3, imagem 2 %32
    • Pull the shield brush straight off the bottom of the floor buffer.
  4. Clarke Floor Buffer 01278A 2016 Rotor Replacement, Remove the Gear Unit Assembly: passo 4, imagem 1 %32
    • Remove the eight 23.1 mm-long Phillips #3 screws securing the gear unit assembly and rotor to the floor buffer's housing.
  5. Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 5, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 5, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 5, imagem 3 %32
    • Remove the gear unit assembly and rotor from the floor buffer's housing.
    • The gear unit assembly is fitted tightly into the housing. You will need to wiggle the assembly back and forth with a good amount of pressure to knock it loose.
    • The gear unit assembly and rotor are very heavy, so it may help to support the assembly from the bottom as you remove it.
    • Re-assembly tip: When installing the new gear unit assembly, make sure the screw holes line up with the housing's screw holes.
  6. Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 6, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 6, imagem 2 %32
    • A round load spring that sits inside the housing may fall out when removing the gear unit assembly and rotor. Be sure to retain it for re-assembly.
  7. Clarke Floor Buffer 01278A 2016 Rotor Replacement, Remove the Rotor: passo 7, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement, Remove the Rotor: passo 7, imagem 2 %32
    • The next two steps show how to remove the bearing from the rotor's driveshaft.
    • Rest the center threaded bolt of a gear puller on the center of the rotor's driveshaft.
    • Attach the legs of the gear puller to the outer bottom edges of the bearing, and tighten the bolt by hand until the gear puller is snug on the bearing.
  8. Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 8, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 8, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 8, imagem 3 %32
    • Use a wrench to tighten the gear puller until the bearing comes loose.
    • Remove the bearing.
    • Re-assembly tip: Use a mallet to gently tap the bearing back on the new rotor's driveshaft.
  9. Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 9, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 9, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Rotor Replacement: passo 9, imagem 3 %32
    • Use two pry bars and place the ends between the rotor and gear unit assembly as far toward the center as possible.
    • Apply force to both pry bars in opposite directions to disconnect the rotor from the gear unit assembly.
    • Remove the rotor from the gear unit assembly.
    • Re-assembly tip: Make sure the rotor's and gear unit's driveshaft key bars line up with each other when putting them back together.
Conclusão
19 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
39.267 Reputação
Autoria de 82 guias
10Comentários do guia
gotta love it when the bearing stays stuck in the top of the floor maintainer housing and you have to work it out somehow.
AUSTIN - Responder
there’s an excessive grinding noise, does anyone what could be it and what might be a remedy? thanks in advance
AYANGA - Responder
Did you figure it out mine is doing the same
James -
in step five if you look where you removed phillips screw there are two threaded holes.if you use screws in those holes and tighten it acts like a gear puller
JAMES - Responder
Very good illustrations.
ADEKUNLE - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 76
Ao todo: 7,057
