Ir para o conteúdo principal
Clarke Floor Buffer 01278A 2016 Power Cord Replacement
O que você precisa
  1. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Handle Enclosure: passo 1, imagem 1 %32
    • Before you begin, make sure the floor buffer is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, imagem 3 %32
    • The rear half of the enclosure is bolted to the handle tube, so you'll only need to remove the front half.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, imagem 2 %32 Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, imagem 3 %32
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects to on the interlock assembly.
  4. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 4, imagem 1 %32
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
  5. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Power Cord: passo 5, imagem 1 %32
    • Use a 3/16" hex key or driver bit to remove the 13.8 mm-long screw securing the power cord's green ground wire to the handle enclosure.
    • This screw is accompanied with a lock washer. Make sure to retain it for re-assembly.
  6. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 6, imagem 1 %32
    • Use a 7/8" wrench to loosen the coupling securing the power cord to the handle enclosure.
  7. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 7, imagem 1 %32 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 7, imagem 2 %32
    • Pull the power cord straight down and out of the handle enclosure.
    • To avoid damaging the wires, remove the power cord slowly and make sure the wires don't snag on anything as they come out.
Conclusão
4 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
29.743 Reputação
82 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 64
Duração total: 1,699
