Ir para o conteúdo principal
Circular Saw Blade Replacement
O que você precisa
  1. Circular Saw Blade Replacement, Blade: passo 1, imagem 1 %32 Circular Saw Blade Replacement, Blade: passo 1, imagem 2 %32
    • Unplug your circular saw or remove the battery before replacing the blade!
  2. Circular Saw Blade Replacement: passo 2, imagem 1 %32 Circular Saw Blade Replacement: passo 2, imagem 2 %32 Circular Saw Blade Replacement: passo 2, imagem 3 %32
    • Press and hold down the blade lock button to keep the blade from turning while you loosen it.
    • Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
    • Your circular saw may already come with a hex key.
  3. Circular Saw Blade Replacement: passo 3, imagem 1 %32 Circular Saw Blade Replacement: passo 3, imagem 2 %32
    • Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
  4. Circular Saw Blade Replacement: passo 4, imagem 1 %32 Circular Saw Blade Replacement: passo 4, imagem 2 %32
    • Remove the arbor washer.
  5. Circular Saw Blade Replacement: passo 5, imagem 1 %32 Circular Saw Blade Replacement: passo 5, imagem 2 %32 Circular Saw Blade Replacement: passo 5, imagem 3 %32
    • Completely retract the blade guard.
    • You can hold the blade guard in place with a clamp while you change the blade.
  6. Circular Saw Blade Replacement: passo 6, imagem 1 %32 Circular Saw Blade Replacement: passo 6, imagem 2 %32 Circular Saw Blade Replacement: passo 6, imagem 3 %32
    • Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
    • Slowly slide out the blade.
    • Use extreme caution when handling the blade!
  7. Circular Saw Blade Replacement: passo 7, imagem 1 %32
    • When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
Conclusão
3 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
38.815 Reputação
Autoria de 82 guias
3 comentários
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
F6 Adhesive Tape - Responder
I think you need a cutting disc in your circular saw
to cut concrete.
Toon Konings - Responder
the problem is that cutting concrete with a concrete disk produces a lot of concrete dust. It will kill your machine. It is not possible to stop the dust by pouring water as you would do with a tile cutting machine.
vief - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 27
Últimos 30 dias: 127
Ao todo: 8,873
