Ir para o conteúdo principal
Circuit Board
O que você precisa
  1. Circuit Board, Battery: passo 1, imagem 1 %32 Circuit Board, Battery: passo 1, imagem 2 %32
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Circuit Board: passo 2, imagem 1 %32 Circuit Board: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Circuit Board, Circuit Board Housing: passo 3, imagem 1 %32 Circuit Board, Circuit Board Housing: passo 3, imagem 2 %32 Circuit Board, Circuit Board Housing: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
    Pergunte ao FixBot
    Comentar
  4. Circuit Board: passo 4, imagem 1 %32 Circuit Board: passo 4, imagem 2 %32
    • Lift the back cover starting at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  5. Circuit Board: passo 5, imagem 1 %32 Circuit Board: passo 5, imagem 2 %32
    • Remove the back cover completely from the phone.
    Pergunte ao FixBot
    Comentar
  6. Circuit Board, Circuit Board: passo 6, imagem 1 %32
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
    Pergunte ao FixBot
    Comentar
  7. Circuit Board: passo 7, imagem 1 %32 Circuit Board: passo 7, imagem 2 %32
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 14-7, Benson Fall 2013 Membro de Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 812
