Ir para o conteúdo principal
Cirago M9030 Screen Protector Replacement
O que você precisa
  1. Cirago M9030 Screen Protector Replacement, Cover: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
    Pergunte ao FixBot
    Comentar
  2. Cirago M9030 Screen Protector Replacement: passo 2, imagem 1 %32
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
    Pergunte ao FixBot
    Comentar
  3. Cirago M9030 Screen Protector Replacement: passo 3, imagem 1 %32 Cirago M9030 Screen Protector Replacement: passo 3, imagem 2 %32
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
    Pergunte ao FixBot
    Comentar
  4. Cirago M9030 Screen Protector Replacement, Hard Drive: passo 4, imagem 1 %32
    • Make sure that the screen of the device is facing down.
    Pergunte ao FixBot
    Comentar
  5. Cirago M9030 Screen Protector Replacement: passo 5, imagem 1 %32 Cirago M9030 Screen Protector Replacement: passo 5, imagem 2 %32 Cirago M9030 Screen Protector Replacement: passo 5, imagem 3 %32
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
    Pergunte ao FixBot
    Comentar
  6. Cirago M9030 Screen Protector Replacement: passo 6, imagem 1 %32 Cirago M9030 Screen Protector Replacement: passo 6, imagem 2 %32 Cirago M9030 Screen Protector Replacement: passo 6, imagem 3 %32
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
    Pergunte ao FixBot
    Comentar
  7. Cirago M9030 Screen Protector Replacement, IDE Connector: passo 7, imagem 1 %32 Cirago M9030 Screen Protector Replacement, IDE Connector: passo 7, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
    Pergunte ao FixBot
    Comentar
  8. Cirago M9030 Screen Protector Replacement: passo 8, imagem 1 %32
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
    Pergunte ao FixBot
    Comentar
  9. Cirago M9030 Screen Protector Replacement: passo 9, imagem 1 %32 Cirago M9030 Screen Protector Replacement: passo 9, imagem 2 %32
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Cirago M9030 Screen Protector Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Cirago M9030 Screen Protector Replacement: passo 11, imagem 1 %32 Cirago M9030 Screen Protector Replacement: passo 11, imagem 2 %32
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
    Pergunte ao FixBot
    Comentar
  12. Cirago M9030 Screen Protector Replacement, Motherboard: passo 12, imagem 1 %32 Cirago M9030 Screen Protector Replacement, Motherboard: passo 12, imagem 2 %32
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
    Pergunte ao FixBot
    Comentar
  13. Cirago M9030 Screen Protector Replacement, Screen Protector: passo 13, imagem 1 %32
    • Locate the plastic screen protector on the front cover.
    Pergunte ao FixBot
    Comentar
  14. Cirago M9030 Screen Protector Replacement: passo 14, imagem 1 %32
    • Grasping the sides of the cover, gently press on screen protector from the inside of the front cover to pop out the screen protector.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Sutardji
Membro desde: 06/29/12
171 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 1-4, Regan SU 2012 Membro de Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 1,208
