Introdução
If your Cirago M9030 MP3 player won't power on, shuts down unexpectedly, or shows signs of water or corrosion damage, you may have a faulty motherboard. Use this guide to replace the motherboard.
The motherboard is the device's main circuit board. It connects and controls parts such as the display, battery, storage, and buttons. When it fails, the device may stop responding, freeze, or show a blank screen.
Before using this guide, check the Cirago M9030 Troubleshooting Guide to rule out other causes.
To prevent electrical shock or damage to sensitive components, completely power off and disconnect the device from any external power source before beginning.
Replacing the motherboard will erase all data stored on the device. Back up important files if possible.
O que você precisa
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
Completely remove the motherboard.
