Ir para o conteúdo principal
Chromo Noria Touch Screen Replacement
O que você precisa
  1. Chromo Noria Touch Screen Replacement, Back Panel: passo 1, imagem 1 %32 Chromo Noria Touch Screen Replacement, Back Panel: passo 1, imagem 2 %32 Chromo Noria Touch Screen Replacement, Back Panel: passo 1, imagem 3 %32
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Touch Screen Replacement: passo 2, imagem 1 %32
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Touch Screen Replacement, Battery: passo 3, imagem 1 %32 Chromo Noria Touch Screen Replacement, Battery: passo 3, imagem 2 %32 Chromo Noria Touch Screen Replacement, Battery: passo 3, imagem 3 %32
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Touch Screen Replacement: passo 4, imagem 1 %32 Chromo Noria Touch Screen Replacement: passo 4, imagem 2 %32 Chromo Noria Touch Screen Replacement: passo 4, imagem 3 %32
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Touch Screen Replacement: passo 5, imagem 1 %32
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Touch Screen Replacement, Camera: passo 6, imagem 1 %32 Chromo Noria Touch Screen Replacement, Camera: passo 6, imagem 2 %32
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Touch Screen Replacement: passo 7, imagem 1 %32 Chromo Noria Touch Screen Replacement: passo 7, imagem 2 %32
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Touch Screen Replacement: passo 8, imagem 1 %32 Chromo Noria Touch Screen Replacement: passo 8, imagem 2 %32
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Touch Screen Replacement, Speaker: passo 9, imagem 1 %32
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Touch Screen Replacement: passo 10, imagem 1 %32 Chromo Noria Touch Screen Replacement: passo 10, imagem 2 %32
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Touch Screen Replacement: passo 11, imagem 1 %32
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Touch Screen Replacement, Motherboard: passo 12, imagem 1 %32 Chromo Noria Touch Screen Replacement, Motherboard: passo 12, imagem 2 %32
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Touch Screen Replacement: passo 13, imagem 1 %32
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Touch Screen Replacement: passo 14, imagem 1 %32 Chromo Noria Touch Screen Replacement: passo 14, imagem 2 %32 Chromo Noria Touch Screen Replacement: passo 14, imagem 3 %32
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Touch Screen Replacement: passo 15, imagem 1 %32
    • Desolder the eight connections.
  16. Chromo Noria Touch Screen Replacement: passo 16, imagem 1 %32
    • Lift the motherboard to remove.
  17. Chromo Noria Touch Screen Replacement, Touch Screen: passo 17, imagem 1 %32 Chromo Noria Touch Screen Replacement, Touch Screen: passo 17, imagem 2 %32 Chromo Noria Touch Screen Replacement, Touch Screen: passo 17, imagem 3 %32
    • Apply downward pressure to each of the clips that hold the touchscreen to the plastic surround.
    • Careful to not apply so much pressure as to break the device! These hinges should move easily.
    • Work your way around the device in a clockwise motion as you progress.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Rohn
Membro desde: 10/30/16
475 Reputação
3 Guias de autoria
Equipe
Baylor, Team 5-6, Williams Fall 2016 Membro de Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 288
