Ir para o conteúdo principal
Chromo Noria Speaker Replacement
O que você precisa
  1. Chromo Noria Speaker  Replacement, Back Panel: passo 1, imagem 1 %32 Chromo Noria Speaker  Replacement, Back Panel: passo 1, imagem 2 %32 Chromo Noria Speaker  Replacement, Back Panel: passo 1, imagem 3 %32
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Speaker  Replacement: passo 2, imagem 1 %32
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Speaker  Replacement, Speaker: passo 3, imagem 1 %32
    • Using your spudger tool, remove speaker from the backboard.
  4. Chromo Noria Speaker  Replacement: passo 4, imagem 1 %32 Chromo Noria Speaker  Replacement: passo 4, imagem 2 %32
    • Using the spudger tool, detach the speaker from the back of the screen.
  5. Chromo Noria Speaker  Replacement: passo 5, imagem 1 %32
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a Soldering Iron, desolder both wires from the motherboard.
Conclusão
Ryan Rho
Membro desde: 10/31/16
201 Reputação
2 Guias de autoria
Equipe
Baylor, Team 5-6, Williams Fall 2016 Membro de Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 116
