Ir para o conteúdo principal
Chromo Noria Battery Replacement
O que você precisa
  1. Chromo Noria Battery Replacement, Back Panel: passo 1, imagem 1 %32 Chromo Noria Battery Replacement, Back Panel: passo 1, imagem 2 %32 Chromo Noria Battery Replacement, Back Panel: passo 1, imagem 3 %32
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Battery Replacement: passo 2, imagem 1 %32
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Battery Replacement, Battery: passo 3, imagem 1 %32 Chromo Noria Battery Replacement, Battery: passo 3, imagem 2 %32 Chromo Noria Battery Replacement, Battery: passo 3, imagem 3 %32
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Battery Replacement: passo 4, imagem 1 %32 Chromo Noria Battery Replacement: passo 4, imagem 2 %32 Chromo Noria Battery Replacement: passo 4, imagem 3 %32
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Battery Replacement: passo 5, imagem 1 %32
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Nguyen
Membro desde: 10/31/16
159 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 5-6, Williams Fall 2016 Membro de Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 454
