Ir para o conteúdo principal
Chromecast Power Button Replacement
O que você precisa
  1. Chromecast Power Button Replacement, Case: passo 1, imagem 1 %32
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
    Pergunte ao FixBot
    Comentar
  2. Chromecast Power Button Replacement: passo 2, imagem 1 %32
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
    Pergunte ao FixBot
    Comentar
  3. Chromecast Power Button Replacement: passo 3, imagem 1 %32
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
    Pergunte ao FixBot
    Comentar
  4. Chromecast Power Button Replacement: passo 4, imagem 1 %32
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
    Pergunte ao FixBot
    Comentar
  5. Chromecast Power Button Replacement: passo 5, imagem 1 %32 Chromecast Power Button Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
    Pergunte ao FixBot
    Comentar
  6. Chromecast Power Button Replacement, Power Button: passo 6, imagem 1 %32
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
    Pergunte ao FixBot
    Comentar
Conclusão
Cameron Heiges
Membro desde: 03/21/18
688 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G6, Baechle Spring 2018 Membro de IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 1,307
