Ir para o conteúdo principal
Chef's Choice M115 Power Cord Replacement
O que você precisa
    1. Chef's Choice M115 Power Cord Replacement, Case: passo 1, imagem 1 %32 Chef's Choice M115 Power Cord Replacement, Case: passo 1, imagem 2 %32
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      Pergunte ao FixBot
      Comentar
    2. Chef's Choice M115 Power Cord Replacement: passo 2, imagem 1 %32
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      Pergunte ao FixBot
      Comentar
    3. Chef's Choice M115 Power Cord Replacement: passo 3, imagem 1 %32
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      Pergunte ao FixBot
      Comentar
    4. Chef's Choice M115 Power Cord Replacement: passo 4, imagem 1 %32
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      Pergunte ao FixBot
      Comentar
    1. Chef's Choice M115 Power Cord Replacement, Power Cord: passo 5, imagem 1 %32 Chef's Choice M115 Power Cord Replacement, Power Cord: passo 5, imagem 2 %32
      • Carefully lift the entire motor assembly out of the case.
      Pergunte ao FixBot
      Comentar
    2. Chef's Choice M115 Power Cord Replacement: passo 6, imagem 1 %32
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      Pergunte ao FixBot
      Comentar
    3. Chef's Choice M115 Power Cord Replacement: passo 7, imagem 1 %32
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 3-3, Harley Fall 2015 Membro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Membros
Autoria de 14 guias
1Comentário do guia
I cannot find a replacement cord with the molded part that passes through the case. Is this something common (from hardware store), or do I need to find a part from the manufacturer?
Luke Shingledecker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 943
