Ir para o conteúdo principal
Char-Broil Grill Burner Replacement
O que você precisa
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: passo 1, imagem 1 %32
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: passo 2, imagem 1 %32 Char-Broil Grill Burner Replacement: passo 2, imagem 2 %32
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: passo 3, imagem 1 %32
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: passo 4, imagem 1 %32 Char-Broil Grill Burner Replacement: passo 4, imagem 2 %32
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: passo 5, imagem 1 %32
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: passo 6, imagem 1 %32 Char-Broil Grill Burner Replacement: passo 6, imagem 2 %32 Char-Broil Grill Burner Replacement: passo 6, imagem 3 %32
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
Conclusão
Dan
Membro desde: 10/01/17
155 Reputação
Autoria de 1 guia
Equipe
Michigan Tech, Team S5-G1, Galliah Fall 2017 Membro de Michigan Tech, Team S5-G1, Galliah Fall 2017
MTU-GALLIAH-F17S5G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 32
Duração total: 579
