Ir para o conteúdo principal
Cen-Tech Seven Function Digital Multimeter Battery Replacement
O que você precisa
  1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Position Device: passo 1, imagem 1 %32
    • Place the meter face down, and the back panel and screws can be seen.
    Pergunte ao FixBot
    Comentar
  2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: passo 2, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: passo 2, imagem 2 %32
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel: passo 3, imagem 1 %32
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
    Pergunte ao FixBot
    Comentar
  4. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: passo 4, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: passo 4, imagem 2 %32
    • Remove the four 7mm Phillips screws holding the circuit board in place.
    Pergunte ao FixBot
    Comentar
  5. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Motherboard: passo 5, imagem 1 %32
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    Pergunte ao FixBot
    Comentar
  6. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Locate Battery Attachment: passo 6, imagem 1 %32
    • After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Battery: passo 7, imagem 1 %32
    • Unsnap the battery from its attachment plate.
    • When replacing the battery with a new one, be sure to properly align battery heads (positive and negative) with snaps. The positive battery head should be connected to the negative wire, and vice versa.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Anna Kihm
Membro desde: 10/13/14
965 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 2-4, Benson Fall 2014 Membro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membros
Autoria de 6 guias
6Comentários do guia
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Osman Vincent - Responder Compartilhar
In at least some of these meters, the caution label has been applied upside-down, so that it covers the screw holes.
dan - Responder Compartilhar
The top of the panel has two tabs engaged (can be seen by carefully examining photos above). After screws are freed, lift the bottom edge first to allow tabs to disengage. Also, routing of battery clip wires is critical; take care that they clear the case edges.
Can't get 2nd screw out!!
KARIN SPURLING - Responder Compartilhar
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
Rodney Grainger - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 40
Últimos 30 dias: 112
Ao todo: 16,259
