Ir para o conteúdo principal
Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch Replacement
O que você precisa
  1. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Position Device: passo 1, imagem 1 %32
    • Place the meter face down, and the back panel and screws can be seen.
    Pergunte ao FixBot
    Comentar
  2. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: passo 2, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: passo 2, imagem 2 %32
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel: passo 3, imagem 1 %32
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
    Pergunte ao FixBot
    Comentar
  4. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: passo 4, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: passo 4, imagem 2 %32
    • Remove the four 7mm Phillips screws holding the circuit board in place.
    Pergunte ao FixBot
    Comentar
  5. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Motherboard: passo 5, imagem 1 %32
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    Pergunte ao FixBot
    Comentar
  6. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Locate 'On'/'Off' Switch: passo 6, imagem 1 %32
    • The 'on'/'off' switch is located directly beneath the dial.
    Pergunte ao FixBot
    Comentar
  7. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove 'On'/'Off' Switch: passo 7, imagem 1 %32
    • Gently remove switch from device by lifting upward.
    • Either clean or replace switch.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Clemson, Team 2-4, Benson Fall 2014 Membro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membros
Autoria de 6 guias
1Comentário do guia
Hi Great site love it, Where can you purchase the copper contacts and is there a technical name for them didn’t know that I could have repaired much craftsman 82040 meter by piecing out the harbor freight free meterand using the contacts which were worn out and non repairable and started to hand make them and then ran across this site. Thanks for the tutorial and being part of the solution as i am an automotive parts rebuilder keeping land fills few of good core since 1988.
Joel - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 2,197
