Ir para o conteúdo principal
Ceiling Fan Pull Chain Switch Replacement
O que você precisa
    1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, imagem 2 %32
      • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
      • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
      Pergunte ao FixBot
      Comentar
    2. Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 3 %32
      • Caution: Let the bulbs cool off before you remove them.
      • Remove the bulbs from their sockets.
      Pergunte ao FixBot
      Comentar
    3. Ceiling Fan Pull Chain Switch Replacement: passo 3, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 3, imagem 2 %32
      • Remove the screws around the base.
      • Remove the fan housing.
      Pergunte ao FixBot
      Comentar
    4. Ceiling Fan Pull Chain Switch Replacement: passo 4, imagem 1 %32
      • Pull the switch out of the fan housing, leaving the wires attached.
      Pergunte ao FixBot
      Comentar
    5. Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 3 %32
      • Cut the colored wires from the switch using a pair of wire cutters.
      • On some switch models, the wires can be detached by pulling.
      Pergunte ao FixBot
      Comentar
    6. Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 3 %32
      • Note the wire colors and the terminal they attach to on the old switch.
      • 1 - Red
      • 2 - Purple
      • 3 - Yellow
      • L - Black
      Pergunte ao FixBot
      Comentar
    7. Ceiling Fan Pull Chain Switch Replacement: passo 7, imagem 1 %32
      • Attach the colored wires to the new switch's respective terminals.
      Pergunte ao FixBot
      Comentar
    8. Ceiling Fan Pull Chain Switch Replacement: passo 8, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 8, imagem 2 %32
      • Put back the switch in the hole in the fan housing from the inside.
      • Tighten up the screws on the outside.
      Pergunte ao FixBot
      Comentar
    9. Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 3 %32
      • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
      Pergunte ao FixBot
      Comentar
    10. Ceiling Fan Pull Chain Switch Replacement: passo 10, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 10, imagem 2 %32
      • Turn the power back on and test the switch to find if it is working or not.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
4 outras pessoas executaram este guia.
1Comentário do guia
I'd recommend adding wire caps to the wires and also black tape.
Richard D - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 150
Últimos 30 dias: 631
Ao todo: 18,968
