Ir para o conteúdo principal
Casio WK-220 White Keys Replacement
O que você precisa
    1. Casio WK-220 White Keys Replacement, White Keys: passo 1, imagem 1 %32 Casio WK-220 White Keys Replacement, White Keys: passo 1, imagem 2 %32
      • Place device face-down
      • Remove 23 16mm screws with Phillips #2 screwdriver
      Pergunte ao FixBot
      Comentar
    2. Casio WK-220 White Keys Replacement: passo 2, imagem 1 %32 Casio WK-220 White Keys Replacement: passo 2, imagem 2 %32
      • Pry up long back panels with plastic opening tool
      • Remove panels
      Pergunte ao FixBot
      Comentar
    3. Casio WK-220 White Keys Replacement: passo 3, imagem 1 %32
      • Turn device around so keys are face-up
      Pergunte ao FixBot
      Comentar
    4. Casio WK-220 White Keys Replacement: passo 4, imagem 1 %32 Casio WK-220 White Keys Replacement: passo 4, imagem 2 %32
      • Pull back panel away from keyboard and out of the way
      Pergunte ao FixBot
      Comentar
    5. Casio WK-220 White Keys Replacement: passo 5, imagem 1 %32 Casio WK-220 White Keys Replacement: passo 5, imagem 2 %32 Casio WK-220 White Keys Replacement: passo 5, imagem 3 %32
      • Remove speaker(s) if necessary to access desired key section(s)
      • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
      • Pop wires out of plastic holders so speaker can be moved out of the way
      • Move speaker out of the way
      • See speaker replacement guide for more detail on these steps
      Pergunte ao FixBot
      Comentar
    6. Casio WK-220 White Keys Replacement: passo 6, imagem 1 %32 Casio WK-220 White Keys Replacement: passo 6, imagem 2 %32 Casio WK-220 White Keys Replacement: passo 6, imagem 3 %32
      • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
      • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
      • Reassemble with new/cleaned keys
      Pergunte ao FixBot
      Comentar
Conclusão
Alexa
Membro desde: 01/24/17
705 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 10-2, Banghart Winter 2017 Membro de Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 Membros
Autoria de 6 guias
1Comentário do guia
Hi. Will this work for broken keys please?
Deborah - EDEN Henderson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 1,990
