Ir para o conteúdo principal
Casio Exilim EX-Z850 Battery Casing Disassembly
O que você precisa
    1. Casio Exilim EX-Z850 Battery Casing Disassembly, Casio Exilim EX-Z850 Battery Casing Disassembly: passo 1, imagem 1 %32
      • Remove battery before you begin disassembly.
      • Use a Phillips #00 Screwdriver to remove all four of the screws on the right side of the camera with the lens facing you.
      Pergunte ao FixBot
      Comentar
    2. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 2, imagem 1 %32
      • Use a Phillips #00 screwdriver, unscrew all four screws on the left side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 3, imagem 1 %32
      • Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
      • Bottom screws are longer than the top screws, so label accordingly for easy reassembly.
      Pergunte ao FixBot
      Comentar
    4. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 4, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 4, imagem 2 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Once all screws have been removed, slowly pry open the back casing of the camera.
      • Gently remove the ribbon cable from the LCD with tweezers.
      • Set aside back casing of the camera.
      Pergunte ao FixBot
      Comentar
    5. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 5, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 5, imagem 2 %32
      • Use your tweezers to hold the camera secure, while you pull the front cover off of the camera.
      Pergunte ao FixBot
      Comentar
    6. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 6, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 6, imagem 2 %32
      • The bottom of the LCD screen is secured to the frame by small pieces of black tape. You will need to peel the tape away to release the LCD screen.
      • Use your tweezers to lift the LCD screen from the frame.
      Pergunte ao FixBot
      Comentar
    7. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 7, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 7, imagem 2 %32
      • Lift screen away from the camera with your tweezers.
      • Flip screen over gently with your fingers once it is lifted far away enough from the camera.
      Pergunte ao FixBot
      Comentar
    8. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 8, imagem 1 %32
      • Use your tweezers to lift the LCD frame from the camera.
      Pergunte ao FixBot
      Comentar
    9. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 9, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 9, imagem 2 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 9, imagem 3 %32
      • Use your tweezers to lift the bar holding the ribbon off.
      • Disconnect the ribbon to release the LCD screen.
      • Use your fingers to pull the LCD screen with the attached ribbon from the camera.
      Pergunte ao FixBot
      Comentar
    10. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 10, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 10, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
      • Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
      Pergunte ao FixBot
      Comentar
    11. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 11, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 11, imagem 2 %32
      • Hold the camera facing toward you. Pull up the bar that is securing the ribbon located to the left of the flash.
      • Disconnect the ribbon by prying it off with your fingers.
      Pergunte ao FixBot
      Comentar
    12. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 12, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 12, imagem 2 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 12, imagem 3 %32
      • With the lens facing towards you, pull the L-shaped frame away from the camera.
      • Do not disconnect any of the wires from the camera when pulling the frame.
      • Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    13. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 13, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 13, imagem 2 %32
      • Locate the logic board to the left of the lens. You will see a bar securing a ribbon. Flip the bar up to release the ribbon.
      • Disconnect the ribbon.
      Pergunte ao FixBot
      Comentar
    14. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 14, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 14, imagem 2 %32
      • Use your Phillips #00 screwdriver to remove the two screws connecting the frame to the back of the camera.
      • Lift the frame away on the LCD screen side of the camera.
      Pergunte ao FixBot
      Comentar
    15. Casio Exilim EX-Z850 Battery Casing Disassembly: passo 15, imagem 1 %32 Casio Exilim EX-Z850 Battery Casing Disassembly: passo 15, imagem 2 %32
      • This is what your camera should look like now that you have the battery casing isolated.
      Pergunte ao FixBot
      Comentar
Conclusão
Logan
Membro desde: 01/10/11
313 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-38, Regan Winter 2011 Membro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 4,495
