Ir para o conteúdo principal
Casio Exilim EX-Z80 Lens Replacement
O que você precisa
  1. Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: passo 1, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: passo 1, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: passo 1, imagem 3 %32
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 Lens Replacement: passo 2, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 2, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement: passo 2, imagem 3 %32
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 Lens Replacement: passo 3, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 3, imagem 2 %32
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 Lens Replacement: passo 4, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 4, imagem 2 %32
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 Lens Replacement: passo 5, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 5, imagem 2 %32
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 Lens Replacement: passo 6, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 6, imagem 2 %32
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 Lens Replacement: passo 7, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 7, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement: passo 7, imagem 3 %32
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 Lens Replacement, LCD Screen: passo 8, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement, LCD Screen: passo 8, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement, LCD Screen: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 Lens Replacement: passo 9, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 9, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement: passo 9, imagem 3 %32
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 Lens Replacement: passo 10, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 10, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement: passo 10, imagem 3 %32
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
  11. Casio Exilim EX-Z80 Lens Replacement, Lens: passo 11, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement, Lens: passo 11, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement, Lens: passo 11, imagem 3 %32
    • Lift the retaining flaps on the two ZIF connectors that secure the the lens ribbon cables to the motherboard.
    • Carefully pull the two ribbon cables from their sockets on the motherboard.
  12. Casio Exilim EX-Z80 Lens Replacement: passo 12, imagem 1 %32 Casio Exilim EX-Z80 Lens Replacement: passo 12, imagem 2 %32 Casio Exilim EX-Z80 Lens Replacement: passo 12, imagem 3 %32
    Heavy-Duty Spudger
    Comprar
    • Turn the camera around and locate the holes on the metal panel.
    • With a heavy duty spudger, gently poke through the holes, releasing the lens from the main portion of the camera.
    • With your index finger and thumb gently pull the full lens out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 921
