Ir para o conteúdo principal
Casio Exilim EX-Z80 Back and Front Cover Replacement
O que você precisa
  1. Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: passo 1, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment at the bottom of the camera.
    • With your thumb, gently press down on the compartment door and slide to the left to open.
  2. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 2, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 2, imagem 2 %32
    • With your index finger, gently pull back gray release lever for the battery to pop out.
    • Gently pull the battery out of the slot.
  3. Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: passo 3, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: passo 3, imagem 2 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: passo 3, imagem 3 %32
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 4, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 4, imagem 2 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 4, imagem 3 %32
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  5. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 5, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 5, imagem 2 %32
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  6. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 6, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 6, imagem 2 %32
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  7. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 7, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 7, imagem 2 %32
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  8. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 8, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 8, imagem 2 %32
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  9. Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 9, imagem 1 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 9, imagem 2 %32 Casio Exilim EX-Z80 Back and Front Cover Replacement: passo 9, imagem 3 %32
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 414
