Ir para o conteúdo principal
Casio CZ-1000 Power Switch Replacement
O que você precisa
    1. Casio CZ-1000 Power Switch Replacement, Backplate: passo 1, imagem 1 %32 Casio CZ-1000 Power Switch Replacement, Backplate: passo 1, imagem 2 %32
      • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
      Pergunte ao FixBot
      Comentar
    2. Casio CZ-1000 Power Switch Replacement: passo 2, imagem 1 %32 Casio CZ-1000 Power Switch Replacement: passo 2, imagem 2 %32 Casio CZ-1000 Power Switch Replacement: passo 2, imagem 3 %32
      • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
      • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
      Pergunte ao FixBot
      Comentar
    3. Casio CZ-1000 Power Switch Replacement: passo 3, imagem 1 %32 Casio CZ-1000 Power Switch Replacement: passo 3, imagem 2 %32 Casio CZ-1000 Power Switch Replacement: passo 3, imagem 3 %32
      • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
      • Be sure to avoid cutting any nearby wires or components.
      • Gently slide all the plugs out of their sockets.
      • This will prevent them from catching on anything or damaging the connectors as you lift.
      Pergunte ao FixBot
      Comentar
    1. Casio CZ-1000 Power Switch Replacement, Power Switch: passo 4, imagem 1 %32
      • Remove the two 5.5 mm screws holding the power switch to the case using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Casio CZ-1000 Power Switch Replacement: passo 5, imagem 1 %32 Casio CZ-1000 Power Switch Replacement: passo 5, imagem 2 %32 Casio CZ-1000 Power Switch Replacement: passo 5, imagem 3 %32
      • Heat the soldering iron and use a desoldering braid or pump to remove the solder from the pins of the old switch.
      • Once the solder is removed, gently pull the old switch out of its place.
      • If the replacement switch doesn’t have pre-attached leads, you’ll need to solder wires to it. If it has leads, align them with the matching holes on the PCB where the old switch was connected.
      • Position the new switch in place, ensuring the leads align correctly with the pads on the PCB. Solder the leads securely, using just enough solder to create a strong connection without any excess that might cause shorts.
      Pergunte ao FixBot
      Comentar
Conclusão
Luke Farmer
Membro desde: 11/05/24
235 Reputação
Autoria de 1 guia
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 311
